Grozer
ConversionSprinterVans.com
How do you remove the plastic trim covers that lock in over the seat locking track, when 3 bench seats are factory installed in a passenger van? The covers at the very front and very rear of the track? Not the covers that have a spring loaded sliding latch that are found between rows of seats (those unlock and come out easy). I also have no problem unlatching the seats, and they appear they will come out simple enough.
But how do you remove the end of track plastic trim covers (Bottom cover in photo)? The ones that have slotted holes? No spring loaded latching clip? I have tried popping them straight up. Also attempted to slide them forward or backward, then up. They seem to be locked in tight. I don't want to force them up and snap off some type of plastic locking tab I suspect exists? Is there a special tool that has to be pushed down through the two slots in the plastic...or some trick to remove these?
