thejingles
I'm partially through my build and installed my ceiling panels not to long ago. I trimmed and fit the Maxxair Deluxe garnish, inserted it into the matching cut-out in the ceiling, and figured that was that with the fan.
I've noticed a strange problem, though. With the garnish installed, the air from the fan (when blowing into the van) is no longer directed down. Most of it instead wraps around with the garnish and is directed out from the fan along the ceiling. Hold your hand directly under the fan and you barely feel anything, but hold your hands up near the ceiling and you feel all of the airflow. Remove the garnish and the air flows down again.
Has anyone dealt with this and/or found a solution? I'm trying to figure out how to install some louvers or something to direct the airflow, but I thought I might try here first.
Thanks for the help.
