It is a bit heavy for a Sprinter 3500. The base weight of a GC is about 4,500 lbs so probably closer to 5,000 with options in the real world with tow gear. If you are at gross weight in the tow vehicle (very easy to do) then you are left with about a 4,200 lb. tow capacity (due to GCWR limitations so doesn't matter if the specified 'tow rating' is higher), thus you would be overweight by a significant amount. You can raise the 4,200 lbs higher (but not higher than the tow rating) by lowering the vehicle weight, but that isn't easy as there isn't a lot of headroom (carrying capacity) to begin with. Of course no estimate beats actually weighing the vehicle combo, which you should do.
I sometimes tow a 2-door Wrangler Rubicon (maybe 4500 lbs ready for the road) with my Winnie View and it is clearly the most I would ever try. It's 'ok' but on the road there's no doubt the drivetrain is clearly at its max. I don't know how longevity will be affected if at all (I am very careful, watch temps, 60 mph max., mostly just day trips, etc.) but it works and many do it. For longer trips or full-time towing I would definitely advise something lighter however. Not that it won't work, but it won't be fun in challenging conditions (mountains, high winds, etc.)
“We have to get the RV weighed,” Jim said as we were packing up for a cross-country trip. “Are you saying that I’m over packing?” I laughed, as I sorted...
leisurevans.com
