Help... No 120V AC from GFCI outlet near sink
rver2be
2019 Unity FX
Hello all. In the process of cleaning and operating everything today, and noticed I have no 120VAC from the GFCI outlet near the sink. On shore power, Dometic AC runs fine, all other outlets work. No green LED from the outlet, when I press the trip button, and reset, the red LED flashes. Is the GFCI outlet bad? I'm led to believe it has been compromised since there is no green LED, but wonder if I'm missing something else here before I rip things apart.
RV2019
2017 Wonder MB
Check breaker on the inverter. The outlet is inverted. Power passes through it even when on shore power. It does not have to be on.
rver2be
2019 Unity FX
That was it! Thanks! I had checked the breakers previously, but all looked OK. When I touched the inverter breaker, it moved as if it tripped. Appreciate the help.
