Adding just 2 rear speakers. Amp needed?
RoverAG
I have a 2019 Cargo which only has 2 door speakers and the center speaker (which is now disconnected).
Apparently I can simply replace the factory door speakers.
I know I will need a line output converter if I add two rear door speakers. Will I also need an amp or only an amp if I add a sub?
Finally, how many channels on the line output converter and amp would I need if I had the two front door speakers, two rear door speakers and a small Bazooka sub?
Thank you
