RVBarry
Hi,I shot an email to the Switch-Pro folks. They confirmed that the unit is able to control the Hi/Low function of the Baja LP9 Pros. However, the 9100 don't have multiple position switches you’ll need to put the high and low beams on separate switches. It seems like that *could* cause an issue if you forget to turn one switch off before turning the other on.
Switch A turns on the power to the light (low) via a SPDT relay (which is 'off').
Switch B flips the relay to 'high' output.
Switch A would be at the bottom before 'T'.
Switch B would be at far left on +12V.
What kind of relays do the lights come with?
