For those who may be a bit thick like I can be, and didn't figure this out right away...
Sikwan helped me.
Profile Posts are public. After clicking your member name in the upper right, your Profile Posts can be accessed by clicking your name within the drop down box. Just clicking the upper right member name will not reveal your Profile Post list. You need the extra step.
"Conversations" are the old PM Personal Messages. They are private the same as the PM's were. When logged in, your Conversations can be accessed by clicking the envelop in the upper right.
I know it is basic stuff for many, but thought that I'd share.
FWIW.
Added:
New members need to enable Conversations.
Here's how thanks to Cheyenne.
Sikwan helped me.
FWIW.
Added:
A bit more detailed explanation. Thanks goes to Sailquik.You need to go into your Account details (click on your username top right) then under Privacy make sure the checkbox against 'Start conversations with you:' is set to 'Members only'.
Default seems to be 'Nobody'.
Merky sprinter,
OK, I/we figured out why I could not send the data card to you.
You need to go to the blue bar at the top of the page.
Look for the envelope symbol.
Just to the left of the envelope symbol is a circle where your Avatar would go.
Click on the circle/dot.
This will take you to "Your Account"
On the LH side, scroll down to "Privacy"
Scroll down (in "Privacy") to "Allow User to:
Scroll down to "Conversations":
Change the setting (up/down arrows) to: Members.
Yours is no set to Nobody!!.
Hope this helps,
Roger
Probably many other new members in the same situation, so if you are not getting
any "conversations", your setting is "nobody".
New members need to check this to get the full value of this forum.
Of course, if you are shy, or don't want anything to do with "conversations", set the switch
to nobody.
Conversations are private, only between the members stated in the email string at the
top of the thread.
