NCV3: 2006-2018 2018 Camper Conversion, Home on wheels. San Angelo, TX
akatc
$85,000
For sale is our 2018 Mercedes Sprinter 2500.
We are the original owners and have a clean title in hand.
This van has served as our home on wheels over the last year. We left the west coast in March of 2019 and did a 50,000 mile road trip around the lower 48, Canada and Alaska. Now that we are no longer traveling full time we have decided to go back to the shorter 144” Sprinter.
If you would like to view a full tour of the van check out our tour video on YouTube
For more pictures.
Details of the Van:
  • 2018 Mercedes Sprinter 2500
  • 2wd
  • Diesel
  • 170inch wheel base (22ft 10inches)
  • 56,000 miles
  • Rear view camera
  • Passenger seat swivels
  • Passenger lowered seat base
  • Heated seats
  • Cruise control
  • Steering wheel controls
  • Crosswind assist
  • All services (fluid changes) done at Mercedes dealers
  • Bf Goodrich Ko2 DT only 5,000 miles on them (new model for heavier vehicles)
  • Sumo Springs in the rear to help stabilize the van
Details on the build out:
Electrical:
  • 300 watts renogy solar
  • 300 Amp hours of battleborn Lithium batteries
  • 6000 watt inverter
  • Victron 100/20 Solar charge controller- Bluetooth
  • Victron BMV-712 Battery Monitor- Bluetooth
  • Battery charging device that will charge the RV batteries while the van is running. You can also jump start the Van from the RV batteries. The battery Isolator from Battleborn Batteries is a special one to not over stress the alternator, it will only run in 15 minute segments.
Kitchen/Bath:
  • Bosch 2.5 gallon electric water heater. Enough hot water mixed with cold to have two hot showers on one heat cycle. (cycle is only 15 minutes)
  • 8 Gallon undermounted PVC pipe gray water holder for the shower. Has a remote motorized ball valve for ease of dumping. Has a hose attachment for RV dump stations
  • 30 Gallon freshwater tank internally mounted so you don't have to worry about freezing
  • Airhead Composting toilet brand new
  • 3 stage water filter system for drinking water with a separate faucet.
  • Under sink 5 gallon jerry can gray water holding system for sink
  • 12 Volt electric refrigerator and freezer Isotherm 130 (130 liters)
  • Shurflo 4008 pump
  • Countertop is a brazilian hardwood
  • 1800watt induction cooktop
  • Extendable shower rod to enlarge the shower space.
Interior:
  • Espar D2 diesel heater with high altitude kit and the 802 controller (you can set the temperature you want and the heater will do the rest)
  • Drawer slide in garage for bikes or totes. 250lbs 4 foot long locking drawer. We stored two mountain bikes and all our biking gear on it to secure the bikes inside the van.
  • 2 Maxxair fans with reversing and auto temp sensor (7500)
  • 3 CR Laurence windows 2 with fold outs and screens
  • 1 full set of custom insulated window covers for every window and fans from Van Made Gear
  • The Bench has custom upholstered sunbrella outdoor stain resistant material with zip off cover.
  • The bench has two locks to store valuables when you're away
  • Brand new Weathertech floor cover for front of van
  • Flooring: waterproof vinyl snap together floor
  • Mattress is a brand new Zinus 3 layer memory foam just shy of King size
  • Custom insulated “headboard”
  • Multiple zone LED puck lights.
  • Custom roll up screens with magnets in the middle for ease of entry and exit.
  • 3 different 2spot 12 volt USB charging locations all NON-illuminated (trust us, the illuminated ones at 2am are annoying)
  • Magnets by bed to hold phones at night.
  • Each side of the bed has its own storage (like a night stand)
  • Three large cabinets above bed for clothes
  • Garage has two usb ports, lights and a 12v cigarette socket for pumps etc
Exterior:
  • Alluminess side ladder
  • Thule 10 foot awning
  • 52inch light bar
  • OEM roof rails
  • Tinted front windows
  • Weathertech rain guards
  • Professional topographical hood wrap
  • Mid door stop
Insulation:
  • First layer 80mil Noico sound dampening material
  • Second was 3m Thinsulate insulation
  • Third a layer of reflectics
Building material:
  • Walls and ceiling: Solid Pine Shiplap
  • Cabinets/Kitchen/Bench/Shower Cabinet grade Birch ply
  • Bed frame is made of Steel square tubing (only weighs 40lbs total) and is removable if needed.
  • Plumbing is mostly 1/2in pex tubing
  • Solar cross bars are custom aluminum bars
  • Custom steel racks for batteries and water tank
We are currently located in San Angelo, Texas. Van is ready to hit the road, we just had the service B done. Oil changed and the fuel filter replaced.
Contact us with any questions.
danielrcriss@gmail.com
503-750-9405
170forsale2.jpg170 small-12.jpg170 small-14.jpg170 small-20.jpg170 small-02.jpg
