2015 316 No lights on just driver side rear also the 3rd brake light out
Dannysafeway
I have no power going to any bulb on the drivers side. I have got a earth. The other side is fine is there a relay or something that controls each side off lights. Please help 2015 316 Panel van
Eric Experience
Denny
This should be easy. Just take out any of the globes and with the switch on measure the voltage on the pins in the socket relative to earth. If you 0 volts on both pins you have a fuse out, if you have 12 volts on both pins you have lost the earth on the loom. Eric.
