steering wheel emblem swap
white whale
Going to swap out for the MB star. Picked up some tips so gives me a chance to play on the new forum with first post since the change.
Knifed around the outside edge to slice through the grime I expect is there.
The 6 o'clock tab is the slim tab. You need thin but beefy slot head on either side and a slow pry and then go to 12 o'clock position to lever up. I wanted to save badge to reinsert while I wait for part. I will be shaving smooth the ribs inside so the new star will fit flush to the surface. I will just use some gasket glue. For general air bag safety, if
you disconnect battery , air bag is non functional 100%?
VERY bad idea .... the air bag cover is really very carefully designed to shatter in a "known" way so that you're not (too) impaled by parts that broke wrong.
By removing the ribbing, you're creating a weak point that may choose to shoot (and flip) the emblem so that it hits your face.
I would tend to think that that ribbing is there to prevent that bit of plastic from shattering.
If they didn't care about "what's behind the emblem" it would have been flat smooth (cheaper for mold design).
In fact, weakening that spot may cause the entire cover to break incorrectly, perhaps changing the entire airbag deployment pattern.
For general air bag safety, if you disconnect battery , air bag is non functional 100%?
... after you've waited two minutes.
Also, do NOT power up with the airbag disconnected, or it will set the SRS light on the dash, which requires a proper scanner to turn back off.
white whale
Did not know you can independently disconnect the A B. That must take some doing, not just an easy reach fuse or plug. Are sprinter air bags the same as all others, there is a sensor at the front to detect impact force??
Quite sure the ribbing beneath the emblem is to support the emblem because they rise in a convex shape to match the backside of the emblem so you can't crush the metal with a push. It is extremely thin aluminum.
All of the airbags in the Sprinter (and, i suspect, any car) have a simple two- or three-wire connector fairly close to the bag.
In the Sprinter, the connectors are yellow plastic, and all of the "explosive" components (airbags, seat belt -retracting squibs) have "shorting bars" inside the connector that short-circuit (i.e. "safety") the bag's wires when they're not plugged in.
Axiom
Florida Van Man
We made a video about this:
Pro tip; trim adhesive expands and is a bad option for this.
And before anyone asks, the battery was disconnected for a few days before we did this.
BrennWagon
He’s just this guy, you know?
I did this mod over a year ago but used a different emblem and used the adhesive tape that was already attached without issues.
With regards to removal of the ribbing, to my eye the airbag cover was made by adding ribbing to the regular MB mold as evidenced by the impression of the star in the center, and careful removal shouldn’t cause issue with airbag deployment. Just my 2¢
