Harmonic balancer
mrcolin2u
2005 Sprinter
I've been reading threads about the HB failing and I'm concerned if this is something I need to do on my 2005 sprinter as preventative maintenance.
The pulley seemed fine when I changed the serpentine belt last year and as of now with 90,000 miles the engine sounds fine.
Is this a job my fellow T1N drivers here think is an absolute must ?
Cheers
Colin
alexk243
KulAdventure
It is not particular easy to fix on the road, but if it does go bad while driving you will notice and you will have some driving time left before failure if you remove the outer rind (if loose) and torque down the HB.
Its not cheap and the job takes a bit of work and special tools so like ECU said above you can wait till it becomes a problem or if you are really worried about it you can just replace it. Depends how far you travel away from a shop/garage and how inconvenient having the van down for a bit is.
Nautamaran
2004 140” HRC 2500 (Crewed)
My 2004 held well past 190,000 miles. Ring removal took ten minutes: belt off, pry off ring, belt on. You can go quite a while with the ring missing.
A less common occurrence is that the crank bolt loosens and the whole pulley moves. If there are signs of this then park the van - it will destroy the keyway if you continue driving for any distance. (most will just find the failed rubber and loose ring)
I replaced the HB/crank pulley last weekend. Took me 3-1/2 hours, and was an excuse to buy a BIG torque wrench, a low profile seal puller, and a flywheel lock. There is enough room to get this done from below without taking the radiator apart.
-dave
Visian
2006 T1N 3500 158" wb
Mine just failed at 170K miles. I started hearing a ringing/rattling sound and saw that the metal flywheel/ring had separated from the rubber isolator and slipped backwards... ratting against the crankcase. Following advice here, I un-tensioned the serpentine belt and was able to slip the ring out.
Truck is currently being repaired... the tech had an issue with how tight the bolt on the end of the crank is. He broke his flywheel blocking tool and had to buy another. Ideally you would find a tech with the official MB tool, which you cannot buy... but my tech said his new tool worked fine.
To answer your question, I would not replace the balancer until it failed. You can drive it a while without the flywheel ring (I have this on the most expert of advice). Take it to a qualified shop with the right tools, especially a 250 lb/ft torque wrench.
I replaced the original water pump and fan clutch while it was apart, along with the idler pulleys and serpentine belt.
JDixon
-dave
Are you able to get fan off without taking radiator off?
Nautamaran
Yes, though you need the tool to counter-hold the clutch pulley, and need to remove the plastic cowl to access the centre bolt.
That said, I did the whole job from under the van without taking the fan off - I had just enough room in front of the pulley for my regular depth 27mm socket and 250 ft.lb torque wrench head (I don’t have rear a/c, just the single serpentine belt pulley).
Pulling the seal with the fan in the way requires a low profile tool: I used a Lisle 58430, and you won’t have room for a cheater pipe from underneath, so have something planned to brace against to get the last 1/4 turn of bolt.
220629
Maybe the factory tire jack, or even a floor jack under the ratchet or breaker bar handle? At that point the specification is degrees, not torque.
Added:
An example on a lighter end of the scale. (18 mm wrench)
ndolphin64
Hey guys, I'm having trouble removing the ring from the HB. The ring is completely loose, but I can't get it to pass in between where is at and the fan / coolant pump.
Do you have any tips of how to get it off? Thank you
marklg
Take a knife and cut the remaining rubber. Be careful as it's a tight location and things can slip. What year do you have and do you have two air conditioners / belts? Ours came right off when enough of the rubber was cut away.
Regards,
Mark
ndolphin64
Regards,
Mark
Thanks so much man! I'll try that. I have 2003 / 3500, no dual A/C.
It just keeps hitting the metal part of the fan/collant area, Maybe the way i'm twisting it/turning it the wrong way.
I'm taking a knife now and carefully cut the rubber. Thanks again!
marklg
It's pretty hard rubber. Now that i think of it, I may have used some tougher tools, like a chisel. I just can't remember.
Here are a couple pictures and a video. Maybe mine is different than yours.
Regards,
Mark
ndolphin64
Hey Mark! thank you!, So... after inspecting it further, it looks that there's still a thick rubber section on the top that's still stuck on the actual balancer, so the ring is not able to come between the rubber and the fan.
If you know of a small tool that can help me "peel/file" the rubber on the top, let me know haha.
I'm thinking there must be a spikey-metal flexible wire or something that I can wrap around the balancer to get that rubber out haha.
PD: also it seems the problem started after the initial attempt to pull it out a few days ago. The guy helping me was going at it, and while prying the ring off, he pulled it from below instead of uniformly forward. This action caused the top part of the ring to go behind, making hard to slide back in now, since there's some rubber on both the ring/HB that doesn't match.
What I'm going to attempt tomorrow is to peel the rubber from the bottom of the HB as well, in hopes that I can get the ring back into place from below, and then hopefully I can pull it forward and then down haha!
