water le
stonechips
There is a water drain hose inside left rear wheel well of our 2014 RT adventurous CS..water runs out of it when I engage the water pump. This just started happening a few days ago. Can someone tell me where this hose comes from and why water would be running out of it?
Thanks in advance
stonechips
As far as I know the Alde plumbing is the only plumbing in that part of the vehicle but thought differently as It did not get cold enough to winterize or cold enough this winter to trip the frost control valve. I will check asap and let you know..Thanks again!
Moto Vita
If you have an Alde system check the air bleeder valve, although that wouldn't be water it would be whatever fluid you have in your Alde system.
