I need to drill two larger holes in the finished outer body of my van; 2" for a fresh water fill and 2-1/2" for a shore power outlet. I've drilled plenty of larger holes in the floor for hydronic hose, vents drains and the like. For this I used a hole saw and grommets. I found that hole saw doesn't make the cleanest edge, but with grommets it doesn't really matter as much. I'm very hesitant to proceed with these new holes in the finished side of the van using a hole saw. I believe the flanges and gaskets for the fill and power should adequately cover the holes if I'm careful, but I'm also thinking there must be a better way to accomplish this.
Can anyone recommend a reasonable way to cut a 2" and a 2-1/2" hole in a finished body panel that provides a cleaner, more precise edge?
