charge air cooler ReInstall - what's up/down ?
nut
59yo audio engineer
I've taken off the Charge Air Cooler a few weeks ago and don't know what's top or bottom :laughing:
It can install in both directions and has no in/out references or marks :thinking:
One port is sootier, caked on, dryer.
The other port is caked but oily. Intercooler hose side?
And should I flush it with carb cleaner or the like?
cheers, neb
Just for follow up, Nut indicates his input/output are the same size, which is probably typical of OM647s. I am inclined to believe the cooler is symmetrical, so can be mounted either way.
nut
59yo audio engineer
Yep, I went with the oilier side being the intercooler hose side and the drier side being turbo side. It doesn't matter which way you hook it up new, but I wanted the same direction after some 15 years. I took it out some weeks ago and didn't mark direction.
I installed the charge air cooler this morning (among other things) and my 05' is running sweet.
Cheers, nut
