San O Van finished at last
sanomechanic
Can you still carry 4'x8' sheet goods flat on the floor?
yes I can.
Everything in van will be modular and can be removed/ installed in 10 minutes or less. The kitchenette I will soon build will be the same way. Bolts up to lashing rails at 3 point. Then plugs into 12v wall socket for power. Will use a quick connect from 22 gallon over wheel arch water tank with gray water tank under sink.
Overvand
'20 144" HR 4x4
Our builds will be very similar, less the stereo work (wife and I are mostly hard of hearing, so wasted on us). What is also eerie is your original van order is only a couple of line items off from mine. Significant enough that I don't want that van, but really really close. Have you been spying on me? :shifty: :shifty: :shifty:
