WALL/CEILING PANELS, L-TRACK, WINDOWS
This part is starting to come together as well. Thought I'd post partial completion in case any last minute great ideas or suggestions emerge. Pics first and then some details.
CNC-cut bamboo panels, L-track, and window spacers, received and ready to try! And no I do not have Mercedes CAD for the wall and ceiling panels, I made my own models in Solidworks.
L-track almost finished, doing test fit on panels. All looks good, although I may have overdone my wire chase space at the wall/ceiling corner. May re-cut the outer ceiling panels to be a bit wider. I still have the short mid-ceiling L-track piece to install at the seam. I may add one rivnut & screw at center of panel in a few locations to control any sag.
Some more details on the design:
Components:
1) 1/4" bamboo plywood from
NW Bamboo for ceiling and most walls
Reasons: I like the look. Linear grain, and will brighten what is otherwise a dark set of colors I've chosen. Will be sealed on both front and back plus edges with a clear finish, will have a stain shop do this for me once they are done. I am leaving a gap where the shower goes--I plan to have the shower use every last 1/4" of space.
2) 1/8" black ABS haircell for lower panels around wheel well in gear garage and behind shower and galley.
Reasons: Waterproof, inexpensive, matches existing Mercedes lower door panels, and is usually hidden behind cabinets anyway. Gear garage will have sailboards, skis and boots, etc. and so everything from waist-level down in walls and floor is 100% impervious to water.
3)
Arctic Tern windows and blinds.
Reasons: Awning opening, double pane, nice screen/shade. I will inset the blinds into the walls. Rectangular holes in wall panels cut to fit outside of blind frame plus 1/4" for a bit of maneuvering room during installation.
4) Expanded PVC window spacers--two 1/2" thicknesses glued together to make a 1" thick spacer.
Reasons: Waterproof, and my CNC guy had some scrap material he gave me and charged just labor to cut.
5)
Flanged L-track from Mac's Custom Tiedowns
Reasons: Panel mounting plus some attachment points, as many have done including Adventure Wagon. I bought their Moab bed kit, which is great. But didn't think I needed the extra structure of all those orange steel braces everywhere else.
I had used the heavier
Cargo Equipment Corp L-track for my floor L-track including the Transit bench seat mounting. But for walls and ceiling I wanted a thinner profile, and it is what Adventure Wagon recommended when I called them. BTW the L-track they use is not actually Mac's, contrary to posts I have read here. It is an even thinner profile than Mac's, source not disclosed by Adwag.
Since Mac's is a short drive away here in Idaho, I was able to go with full 14' lengths for my ceiling. Given the wide 16-24" spacing of the ceiling ribs, I wanted to have continuous pieces for more strength. I'll mount some overhead clothing cabinets to them, not lifting engine blocks or anything like that.
On the walls, I cut into 3 sections to enable removing portions without taking out all cabinets. Since those runs are on continuous metal with screws spaced at about 6", I was less concerned on strength there.
6)
1/4-20 rivnuts and
stainless flat head screws from McMaster-Carr
After reading up on corrosion I settled on zinc-plated rivnuts, stainless screws, and this
anti-sieze lubricant.
