NotSure 92
Not sure what to do at this point. My sprinter 2006 Dodge 2500 will not start. Single click, no turn over. This happened 3 months ago I disconnected the battery terminals and tied them together for 1hour, van started up no issues till the other day. Now it's every time. And if I do the battery reset procedure it takes over night before it will start, which is still not 100 percent working. Things that have been done.
-Starter was replaced within the last 8 months
-Battery tested good at interstate today
-SOS diagnostics just returned our ecu and skreem module as reprogrammed, worked in test vehicle before sent back to us.
-I have voltage across starter relay pins 86 and 85. Pin 30 has continuity to ground and then shows voltage when trying to start.
-Starter relay clicks when I key on the ignition then again when I turn to start.
-Used jumper cables from battery ground to engine to help determine if I have bad ground.
I don't know what to do. The van is our home, the wife needs it this weekend for work/traveling two hours away. I really need to figure this out asap. Any other tips would be greatly appreciated.
Thanks,
-reed.
Thanks,
-reed.
