Hi all need help 150 amp fuse
Stevie boy
So I’ve purchased my third sprinter and we have decided to turn this one into a moto van for our family to travel around to races. So far I have insulated wired installed two 6 volt batteries , inverter lighting . My latest project I installed a diesel heater, during the process I put the power wire on the battery terminal to make sure it turned on and it did . So I put everything back together except for the power wire ( I will install into fuse block under the seat if ican figure it out ) . But here’s my major issue I can’t start the van now , marker light tun on and all the lights in the dash are on except for the glow plug light but literally every other light is on .no other power in the van and key turns but nothing not even a click . Battery shows 12,7 volts I’ve checked all the fuses and they seem fine . Now what ? I need help,figuring this out and I’ve seen so many useful comments on here maybe someone knows what I’ve done . My sprinter is a 2012 170 it’s the cargo series
Re: Hi all need help
Check the ground connections.
Check that the tail lights (and brake lights) are not screwed up (bulb twisted incorrectly, something bent).
The 2007 wiring diagrams will be very close to your 2012:
http://www.diysprinter.co.uk/reference/2007-sprinter-service-information.pdf <-2007 MB service manual
http://www.diysprinter.co.uk/reference/2007-sprinter-wiring-information.pdf <- MB wiring diagram from above
http://www.diysprinter.co.uk/reference/2007_Wiring-sprinter-2500.pdf <-- 3rd party wiring diagrams
Stevie boy
Nothing else was touched van worked great now ther is no power except for instrument lights and marker lights . I checked rear lights there fine .turn key not even a click and no glow plug on dash
Eric Experience
Steve.
Probably something very simple. Move the gear change to make sure the inhibit switch is not open. The big fuses on the battery terminal,check them and clean the terminals. Eric.
Stevie boy
Steve.
Ok got,it figured out there are,three fuses beside battery in a covered area the middle fuse 150 amp blew . I dint even know there was a fuse there , big ones . Well relief thanks for the help great outlet to ask for help and get great ideas
hkpierce
'02 140 Hi BlueBlk Pass
Wow - what caused that? 150 A should have fried something!
