safeandsoundauto
There have been several posts on Radio removal in the W907 Sprinter and Today I had one in my shop to add speakers/amp, etc. Below are the pictures and how-to removal of the 7" or 10.5" radio.
The outside radio bezel is indeed different than the base radio in that it is screwed in. the most difficult part of the disassembly is getting the Factory air vents to pop loose. pry carefully with a thin plastic trim removal tool or similar.
Behind the vents are a T25 torx screw holding in the outer dash bezel. remove both Screws and carefully pry the outer piece out, the touchscreen is attached to the outer bezel and will come out with it. remove the two connectors from the screen and the two connectors from the lower control panel and set bezel aside.
