High Beam Signal wire?
VanLifeFreedom
Anyone on here know what color wire is the 12V+ signal for the highbeam on the VS30?
I was test lighting the wire feeding the plug on the headlights and when I tap the green wires it turns off the high beam for some reason?
Any help would be appreciated.
Tom
Rauch
I was just testing the same today. There is some Can Bus voltage 2V give or take and one 12V wire, but nothing changes with highbeam activation. Any ideas on tapping highbeam to run driving lights off a relay on the vs30 with LED? Maybe allow the negative on the fog lights to trigger the relay?
Laserbill
Any idea on what to use for those with halogens? Would like to trigger aux lighting via high beams as halogens leave something to be desired off road.
Laserbill
I have halogens and am interested if others know color of high beam 12 volt wire. Looking to tap into it for high beam trigger for off road lighting.
