Thank you very much!Hi Mr Makai
+ Three exposed screws along bottom edge
+ 5 circular plugs you need to pop out (trim tool) with screws behind them
_ 2 in lower cubby, 1 behind door handle, 1 in door pull pocket, 1 at top outermost (facing your elbow when seated)
+ Pop out small trim piece around door lock stalk where it meets glass
You can then start at the bottom and work your way around popping the plastic clips
The bottom edge of the door panel has hooks that hold it to sheetmetal
Once you’ve popped off all the body clips, the door panel will rotate out so you can unclip the wiring and the door rod from the door handle
Then the door panel can rotate down towards you a bit more and you can lift it out of the recess that the hooks sit in
There’s a couple YouTube videos if you need visuals
If I find url I’ll post it up
Sent from my Moto Z (2) using Tapatalk
