Looking for every for a compact kitchenette or sink option that anyone can install and use...I eventually found these and now brought them into USA. I had been wanting this type of a solution for ever and just could not find it here in the USA or at least find an example of how to build one. There is nothing this compact that is truly plug and play with zero assembly.
Super compact sink and kitchenettes. Requires no assembly for the DIY person who doesn't have the skills to build own cabinet or looking for an ultra compact solution to fit under bed or behind/beside seats. Designed to be bolted to floor, can use even your cargo D ring mount with a backing plate. Plugs into any 12v outlet. Has grey and clean water jugs. All inclusive. Stove powered by 1lb propane bottle. No door to swing out and get into the way of open space. This is not a substitute for a full size cabinet, plenty provide this, its an ultra compact solution fully assembled for a true plug and play and modular as it can be removed easily, under 30 lbs.
Dimensions and Pricing: (as likely that would be asked)
Kitchenette dimensions ~27" high X 16" deep x 29" wide $1650
Sink dimensions ~27" high X 12" deep x 24" wide $1400
