The biggest mistake people make is NOT turning the key to ON. ON is the second click NOT the first click of the key.
Took me 4 years and blue thumbs to figure that one out.
I have been able to reset my 2007 Sprinter twice by following the procedure repeated here many times. However, when I reset a one wrench indicator today, I expected it to become a 2 wrench indicator for the next service. Isn't that what is supposed to happen? I used the .51 screen to do the reset. Must I reset something else also?
Treadmill, try this to reset your Maintenance reminder:
Just note that MY 2008 2500 does NOT say "service scope in XXX miles/kms".......It says "service due in XXX miles/km" and mine resets with the drivers door closed.
Reset Assyst, steering wheel with buttons.
1.) Switch on ignition. The total kilometers (miles?) must be displayed in order to reach the "service scope x in xxx km" menu. Should the total kilometers not be shown in the display, press the system selection button in the lower control panel (S111s3) until the total kilometers are displayed.
2.) Press the upper control panel on the scroll forward/back button (S111s1) several times until "service scope x in xxx km" appears in the multifunction display of the instrument cluster.
3.) Press button 0 (lower left) on the instrument cluster for approx. 30 seconds until a beep sounds.
4.) Press the lower control panel of the system selection button (S111s3) once.
5.) Press the upper control panel of the scroll forward and back button (S111s1) until "Service in xxx km" appears in the multifunction display of the instrument cluster.
6.) Press button 0 on the instrument cluster. The menu "Carry out" appears in the multifunction display.
7.) Press the upper control panel on the scroll forward and back button (S111s1). The selection menu "Oil types" appears in the display.
8.) Press the upper control panel on the button + and - (S110s1) repeatedly until the desired oil type is marked in the display.
9.) Select mark oil type with the upper control panel of the scroll forward and backward button (S111s1).
10.) Press button 0 on the instrument cluster for approx. 3 seconds until the display "Service confirmed" appears in the multifunction display.
11.) Press the upper control panel of the scroll forward and back button (S111s1). The newly adjusted service scope appears in the display.
GOOD LUck and make sure you come back and leave a message if it works or not.
For 2007, the cycle is
[and so on....]
- One Wrench
- One Wrench
- Two Wrenches
- One Wrench
- One Wrench
- Two Wrenches
I just discovered how to re-set my assyst on my 2008 Sprinter by myself with no tools, etc. I have NO steering wheel buttons. 3.0 Diesel with 160,000 miles on it now.
Here is the procedure.
How to reset ASSYST on 2008+ Sprinter W/O steering wheel buttons
1. Doors shut, Turn key to on position.
2. Wait for reminder mileage to clear (few seconds)
3. Hold “0” button down until you hear beep.
4. Release “0”, push “M” button repeatedly until see reset ‘51’
5. Release “M” button Press “0” button(6 seconds)until #2 displayed
6. Press “0” again briefly & see reset message.
7 This resets for 10,000 miles
Thanks for listening, It's taken me 4 years to get this information. Hope you can use it.
Steve Jenner (jenner@flash.net)
There may be some pitfalls to playing with the buttons. I'm not saying that would stop me personally, I'm just passing on information.
Here's a recent example. In this case disconnecting the battery worked to get back to normal operation. Maybe he can duplicate/outline the button sequence needed for future dyno tests?
Dynamometer test mode on
https://sprinter-source.com/forums/showthread.php?t=28387
Yes reset it. The count down will start a new 10,000 mi duration from the reset mileage.
Just tried this today and can confirm that it works for a 2011 with steering wheel buttons.
Thanks![]()
