mcjohnson5174
I made a couple diagrams that I think might help others...once I get this figured out I will make a final one.
First here is a quick ref for under the seat
Second here is the F150/1 labels. Guys have said to tap off there. Not super sure on these, but I think so. The open spot is #2, seems like a logical tap, but it isn't hot. Needs a bridge/jumper?
Or could just screw on to top terminal of battery too?
Here is the F150/4. Read a lot about this location, just not any useful instruction. The Fuse Assignment Supplement 2018-11 does not appear to be accurate. I heard there is another one?I have a 2019 4x4 and this supplement was included in my stuff, but does not appear to match up. I just focused on 1-7 as I think this appears to be a logical place to tap. No idea what, if any fuses are attached? Why not tap in here? If so, where?
For lower voltage...there is the EK1 also..
Im trying to achieve two things:
1. Tap the Goal Zero Yeti alternator charger
2. Tap for a fuse panel when GZ is not in van.
Matt
Im in Minnesota, and have yet to find a knowledgeable pro within a days drive. For all of you that are in areas that have them, consider yourself lucky.
Matt
