Part It Forward - Karma
vanski
'05 Box Snow Camper
3 person bench seat I need gone.. I'd say it's in 8/10 shape. I don't have the mounting brackets. Walnut Creek CA, pickup only.. A pillar plastic piece as well that goes over the seat belt although the corner edge has been cut away.
Oil pump filter removal tool. Somehow I ended up with two of them, willing to send one to someone else that needs it.
Just finished installing some new rollers for my sliding door, but not before ending up with the incorrect middle slider. My dually needs the longer version, but the set of rollers that I bought included the short one. I'd like to offer up this new aftermarket middle slider to anyone that wants it. It should fit 2002 - 2006 2500, right hand side sliding door, if I'm not mistaken. If your sliding door has a plastic cover on the exterior of your van the way mine does I don't think this one will fit!
Filter removal tool & slider have been spoken for/sent out.
Next up (I'm really good at ordering incorrect parts!) I have a new heater/ac blower resistor, it is the single 4-pin plug type. It is a cheapie off amazon and I'm past the return window (the quality does appear to be good when compared to the correct fitting MB part that I picked up from sd euro). I'll gladly pass it along for that sweet sweet karma, let me know if you need it!
Free thermostat unit. This is the basic one without ac. I originally needed to replace the white wheel but decided to just use super glue instead. Offering up these parts for anyone in need. Just pay postage fees.
Sent from my GM1917 using Tapatalk
OChrisJonesO
Chris Jones
I've got a stock 90 amp alternator for free to anyone who needs it. Used & is fairly dirty/oily but works fine. Upgraded to a 200 amp for a camper build out. Will ship if you pay postage, otherwise free pickup in Dayton, OH and surrounding areas.
Charlotte NC
Complete front suspension minus sway bar and steering rack. New ball joints, outer wheel bearings, and tie rods in the last 30k miles, rotors and pads with plenty of life. Calipers and bearings in good shape. Minimal rust, all parts are straight, and drove well when removed.
16" steel wheels with tires. Tires have about 1000 miles left 245/75R16. 2 wheels avaialible now, the other 3 in late summer.
Brake pad sensor pigtails 2X
Wheel speed sensors with ~20" of harness 2X
I will ship the smaller items at receivers expense.
Oilburner
2004 2500 140"cargo l/r
Thermostat with housing. I purchased new one hoping my van will warm up faster, but didn't changed anything. Can ship it to you.
This is part of cooling system, under the hood, not inside the cab. Private message (PM) me if you need it.
sassmatt72
2006 low top 10 pass
will this fit my 2006? I'd be very interested as an emergency back up for my next long trip....
thx.
I'm in SF area so shipping to 94930? (PayPal for shipping costs?)
matt
tbuyan
Anybody need/want a really nice wheelchair lift? Free to a good home.
Thanks for reposting this to the Karma thread. I intended to do it when I got some photos and a better description.
VAMANOS
first dibs to niagara
but. I think I need this. Does it have AC? mine just keep spinning in circles. Im not exactly sure yet what I need to fix it
Ggoytia
Charlotte NC
Hello, curious if you still have the Brake pad sensor pigtails, and the Wheel speed sensors available? I have a 05 t1n, can you confirm they will fit. Also zip for Fort Worth,tx is 76179
niagara
... just in Casey
I have the original set of 15” wheels for my ‘06 118wb Sprinter. The tires are still on the rims, but 2 will need immediate replacement as they’re SUV rated and worn. The other two have a little life, but best to replace asap. More or less, you’re getting free rims. Can ship but may be cost prohibitive with the tires on there. If interested just shoot me an email. :thumbup:
tbuyan
Front buckets (cloth), 2nd row 3 Passenger bench (cloth), complete 3-piece driveshaft w/o hanger bearings for LWB. Vancouver, WA.
Charlotte NC
16" steel wheels with tires. Tires have about 1000 miles left 245/75R16. 2 wheels available now, the other 3 in late summer.
Sensors are gone. The rest is still available.
A reminder, contact folks via PM to keep the thread uncluttered.
bcman
I have 2 sets of seat brackets from my 140WB passenger van (one for 3-person bench, one for 2-person), along with the e-torx bolts. Free for local pick-up (Silverado, CA) or will ship for actual UPS charge + $5.
EDIT - Gone.
Charlotte NC
16" steel wheels with tires. Tires have about 1000 miles left 245/75R16. 2 4 wheels avaialible now.
The sensors are gone, the subframe is gone. I still have the control arms, knuckles, bearings, brakes, etc.
Also available in Charlotte. A complete 2500 rear axle. ~180k miles., in good condition, regular oil changes, no noise, backlash is good, no leaks. Some surface rust. NO sway bar, brakes are available as well.
