Part It Forward - Karma
This thread is for users who want to give away things they don't need. These should be T1N related. Parts, tools, etc.
Rule 1: Do not post items you intend to sell. This is free (as in beer) only.
Rule 2: If you want any of the parts listed, PM the listing user.
Rule 3: Once an item is gone, the listing user should quote their original post, followed with a "Gone!"
Rule 4: Keep the random banter, comments about the postings to a minimum.
Rule 5: Post your location, and if you will ship (obviously on the receiver)
Karma: DO NOT receive items with the intent of selling them. Doing so is extremely bad form.
DO NOT request items of any kind. If you want something - post in the "Want to Buy" forum.
To kick things off. I have the following items I want gone.
Located in Charlotte NC.
Transmission crossmember. Lightly bent from previous owner jacking it. No significant rust. Will consider shipping.
Transmission bracket, and rubber isolator. 180k miles, in good condition. Will Ship if someone really needs it.
Custom made tank that fits under the sliding door. Should fit on 140" and 158" vans. See my build thread for details. It has a couple extremely slow pin leaks. Doesn't drip, but will show a bit of a stain on the surface. Holds about 10 gallons of liquid, and has 2x1/2" NPT ports. Too heavy to ship. It is made from 10 gauge galvanized steel. It attaches with 4 rivnuts. Two in the body skirt, and 2 in the frame rail. I used it as an auxililiary fuel tank, it was filled with a transfer pump (which comes with it). It could also be used for a gray tank.
https://sprinter-source.com/forum/showthread.php?t=41215&page=28
Ciprian
Spark Plugs not allowed!
Two 16 in steel rims. Located in Jamestown, TN. Will not ship.
Sent from my moto g(7) using Tapatalk
vanski
If it’s winter, I’m probably skiing..
I'll part with a used but known good radiator... for someone who needs it (not just a spare).
Also, I have a bunch of Espar Hydronic D5 parts from older cocked up Espars. I'm sure some of the flame sensors, combustion fans, glow plugs, etc are good.
No shipping..
East Bay, San Francisco CA.
Nautamaran
2004 140” HRC 2500 (Crewed)
Calgary, Alberta, Canada.
I’ve got a three-seat bench complete with the three anchor plates.
It’s in great shape but needs a home.
It’s the “narrow” second row bench, not the wider rear bench (that one is in the van - my kids like the extra hip room... ;-)
I’m driving to Idaho Falls on November 10th, returning to Calgary Nov 12, and could drop it off somewhere along I-15, otherwise it’s in my overfilled garage waiting for you.
-dave
Also available in Charlotte NC. Complete 140" driveshaft 180k miles. Includes carrier bearing. No rust, all joints smooth and good condition. Too big to ship.
Hoka
I have a metal ( no window or door ) bulkhead partition for a 2005 T1N. It's in fairly good shape but does have a dent in the center bottom from freight sliding into it. In Seattle area no shipping.
turbodave
Central Maine/Summer Somewhere Warm/Winter
Southern Maine-no shipping. Metal bulkhead partition w/door for a high roof T1N. Also the stock plastic wall panels. All in good shape van had 30k when removed.
Dave
brownsuitcase
I have all the badging from a 2005 T1N. Including "sprinter", "2500", the front "ram" badge and the four Ram wheel hub covers. Located in Nova Scotia, Canada, can possibly ship within Canada.
sassmatt72
2006 high top long, Fully converted by me
2 person (Transit) seat w floor mount quick release plates.
Marin CA, gotta move 1st, so bench is free (or 6-pack of Lagunitas beer?)
2 person bench gone.
Fudgefactor
2004 OM647 3500 C-Cab
Seven (7) 15" steel wheels, six (6) lug from a 3500 with tires. Five have at least 5,000 miles left on them, one has about 10,000 left and the last one has no tread-steel belts only. Local pick-up only.
Fletch9871
2 15” Vanco tires with a lot of life left in them. Local pickup only.
Charlotte NC area.
Keep Rolling...Chris
SkyGypsy
Santa Cruz, California
- Rear Window Security Cages, very good condition
Will consider shipment. No longer using, would hate to just junk em
ECU
2006 T1n 118 Sprinter
T1n Headlight trim. The parts under the headlights and the U shaped piece for the grill.
Also have the back fender flairs.
OChrisJonesO
Chris Jones
I've got a nice condition dodge front hood grille and a sliding door sill/step that is a little beat up but still functions just fine. Dayton OH, pickup only. Feel bad throwing them out but too costly to ship!
GC1234
2006 2500 140wb
I have a radiator to part with. Full disclosure, I replaced my water pump which was in pretty rough shape, a lot of orange/rust on it. Ended up being proactive and replacing the majority of the cooling system including the radiator to try and get my van in tip top shape. You can see a mild orange coating on the radiator inlets and outlets. Transmission cooling lines were not hooked up to the old radiator, so I don't know if there is a problem with that part of the unit, but the engine cooling side had no leaks. Located in Tampa, FL, will ship.
220629
Sending a Sprinter with remote FOB's to the scrapyard?
You might consider offering the FOB's to other owners [to use the case/parts]. I don't know if SOS can reprogram for them, but I suspect that they can.
Nope. 99sport checked with SOS. No go.
Bottom line, while used fobs might not be reprogrammable, plenty of folks (me included) would find the fob shell valuable, so save those fobs if you junk the van!
Yep.
But back to the Part It Forward topic please.
A FOB thread has been created here.
Options for Remote FOB
https://sprinter-source.com/forum/showthread.php?p=839239
BrennWagon
He’s just this guy, you know?
Free plastic floor plug for the long leg of a passenger van. Local pickup or I can ship to you
MB part #901 684 1218
