Axiom
Mike from Florida Van Man
So I'm driving my 2006 HC 2500 140" about 5 mins up to the autoparts store. Taking off from a stop light, it shifts into first okay then it tries to shift into second but it gets really sluggish...next thing I know it bangs into gear, lurches me forward a little bit, and I get the dreaded check engine light. Now I'm stuck in first gear and no amount of key resetting is helping me. Can't manually shift either.
I get it home and check the EGS codes on the iCarsoft and it says....
P2203 - Speed sensor 3 is faulty
In CDI, I also had the following codes which I'm sure are unrelated to my problem, yet still triggered:
P2359 - Boost pressure
P2511 - EGR Valve Signal Circuit Shorted to Ground
P2225 - TCM DRC Speed Sensor Voltage Fault Present
About 1000 miles ago, before we started driving this van we dropped the pan, cleaned the valve body and conductor plate, replaced filter, and put in some genuine MB transmission fluid. It also got a brand new plug at the transmission side and the plugs feel dry under the driver's seat going to the TCM.
I have yet to drop the pan yet since I'm a little worried as to what I'll find. But mostly I'm just trying to figure out if speed sensor 3 is part of the wheels or on the conductor plate?
Cheers!
Cheers!
