NCV3: 2006-2018 Dodge '07 3500 Sprinter (Duelly) (Longmont, CO)
Reclaimed this 2007 3500 Series "Duelly" 144" Sprinter from a man with too many toys. :) "Duelly Sue" has seen two separate mechanics, not for a bunch of mechanical failures, but rather to ensure I got the same diagnosis! She will see many many more road trips ahead of her. The starter batteries are a year and half old, same goes for the tires.
She's all current with all emissions, fluid changes, the whole lot. Recently received a new windshield and a factory recall got her new air bags for both driver (new steering wheel) and passenger.
I decided to keep the bulkhead wall and take advantage of it's many benefits. You will be surprised how well it holds back the heat during these hot 90+ days.
VIN: WD0PF345X75219816
Located in Longmont, CO
Asking for $51K or Best Offer.
Build Specs:
- Fully Insulated
- Diesel Heater
- Norcold Energy Efficient Fridge
- 2x100w Renogy Solar Panels
- 30A Victron MPPT Controller w/ Bluetooth
- 100ah LiFePO4 Batteries
- 1800w /55A Xantrex Inverter with 110vac Shore Power
- LiFePO4 / AMG Battery Solenoid (if you don't know what that is, it essentially redirects power from the starter batteries to the "house" battery when driving once your starter batteries are topped off.)
- All Critical Wiring has Proper Circuit Breakers in-line
- 2 Burner Gas Stove
- Deep Stainless Steel Kitchen Sink w/ Spray Nozzle (includes integrated stainless steel straining basket and flush fitting cutting board.)
- 16 Gallon Fresh Water Tank
- 6 Gallon Grey Water Tank as well as Floor Drain
- Maple Butcher Block Counter Top
- Maxxfan
- Pioneer AVH 310ex w/ Backup Camera and Apple CarPlay
- Carbon Block Filtered Water
- Locally Source Blue Pine
- Lonseal Flooring
- Camco Cassette Potty
- Dual Zone Overhead LED Lights on Dimmers
- Cabinet LED Lighting
- Touch Enabled Flexible Goose Neck LEDs
- 110vac Outlets
- Front and Rear Dual USB Ports
- Dual Starter Batteries
- Driver & Passenger Chairs Can Adjust to Passenger Weight to provider a softer ride for the long hauls
*more photos
https://www.rockymountainadvantures.com/project-gallery-page
