calin_316cdi_t1n2000_4x4
Hi, all. Had this issue with random turn signals about 7-8 months ago, read all the forums, cleaned contacts, exchanged relays between them, all pointing to a rather "mechanical" problem, something that had just not worked as before.
I finally noticed that in some position of the steering relay (= the big "Yoda" piece under the steering wheel), everything works.
My conclusion: plastic deformed in time as that piece is supposed to be pushed by bolts, but these bolts created some leverage. I used some plastic tie wraps to tighten Yoda back to its position at the end that was pushed away from the column by the leverage and problem solved since then.
Some may have other issues, but mine was purely mechanical deforming.
