Transfer Case Fluid
mr.mcvay
ATF 236.14 or 75/90 Gear Oil?
Is it me or is this info not in the manual? There was a mention that someone found the info on the Oberaigner website, I wasn't able to, and they claim gear oil...
Claude15
2015, the spec is not in my manual, it is gear oil, see your dealer for the spec. (can’t remember)
Talked with Service Advisor a week before appointment for B service including changing fluid in front diff and transfer case. He assured me everything would be in stock and ready for the service.
During the service, they informed me they did not have the gear oil (shipped in next day) and also did not have the sealing washer for the transfer case. (7 days from Germany) Found an aluminum washer at the local Mazda dealer for them (exact match), and was on my way. (they did have the washer for the front diff)
mrmcvay, Surely you jest! haha
You are far from alone. I believe there is a setting that can delete postings from a specific member showing up on your screen. I have been tempted many times, but realize any calling him out would result in nothing changing. Meanwhile, we can ignore his useless input as each of us sees fit. No use poking the bear.
mr.mcvay
Thanks Claude for your sincerity and enthusiasm, but, your reply is useless. 1) What ****ing day did I post my question? 2) Know many service departments/parts counters open today? 3) Man you have to get tired of wading through internet bull**** to get to a should be easy answer for maintaining your rig? 4) So glad to hear you DIY'd the **** out finding those washers - nice job.
Claude15
Sorry, didn’t realize you needed the fluid right away.
Just trying to give you (and maybe others) a heads up on the dealer not being up to speed with the 4wd model.
Sprinter SS
Please note front diff is 75/90w hypoid but not with limited slip modifier ( like Mobil 1). You have to use MB 235.8 spec, which is not super easy to find. Mobil Delvac 1 synthetic is available here stateside, but not much else on the Bevo list is.
Flagster
Amsoil meets this specification but not on Bevo list:idunno:
Sprinter SS
I found three of the products on the BEVO list source able here stateside. Only the Delvac in stock in liters, did not need a 5 liter jug.
Not surprisingly dealers are somewhat not up on these details.
Sent from my SM-G950U using Tapatalk
Wrinkledpants
For the diffs - Redline 75W90 GL-5 GEAR OIL meets MB235.8
It doesn't technically "meet" the standard as Redline is not going to show up on an approval list. They're saying they built it to meet the standard. It's a bit of false marketing on their part.
That said - I love me some redline diff and trans fluid. It's what I'll be switching to when that time comes.
How did differential lube talk get into this TRANSFER CASE FLUID thread?... this could be extremely confusing and damaging if the wrong lube is used in the transfer case vs the differential!
OK, back on transfer case fluid... I did the drain and fill, 1 QT ATF (NOT gear oil) I chose to use 100% syn Amsoil.
EZ-PEEZY:
1) Snip the two zip ties that hold the end of the solenoid electrical plug and remove, set aside.
2) Remove (14 mm hex) fill plug.
3) Remove drain plug (3/4" or 19mm socket) - do not lose the washer if you plan to use it again.
4) Clean the metal filings off of the drain plug magnet.
5) After complete drain, re-install drain plug, preferably with a with new washer.
6) Fill through fill plug hole until the fluid (ATF in my case) starts to run out.
7) Re-install 14 mm fill plug. I chose to add some Loctite to the threads of mine.
I used 100% Amsoil synthetic ATF fluid. It took very slightly over 1 quart.
I hope these photos are useful.
Cheers!
Flagster
Just changed our Transfer case for the second time at 68K miles. Took a bit less than a quart. No metal on magnet. First change was at 40K... MBZ ATF/236.14
I was able to get fill bolt off with extension and did not disturb electrical connector...
