We have a 2007 Pleasure-Way Plateau TS with Creation windows.
One of the actuator nylon wheels broke.
The actuators are Kinro 4" 2 Arm Actuator
https://www.pellandent.com/Kinro-Four-Inch-Two-Arm-Operator
$54 in 2019
To R&R:
1. pull out plastic limit spacer in actuator track on window
2. crank arms to center
3. lift off window
4. drill out rivets
5. enlarge frame hole to 15/64
6. mount actuator with 2 #12 x 1/2" bolts with head to outside
7. fit actuator to track
8. crank window in until almost closed
9. fit plastic limit spacer
Doing the actual job takes about 30 minutes, after hours of fruitless web searching
- Ian
$54 in 2019
To R&R:
3. lift off window
4. drill out rivets
- Ian
