Hi. First post on the forum. I bought a 2006 tall and long about a year ago and have been slowly fixing it up to turn into a home on wheels.
Having a weird issue where the instrument cluster doesn't always light up when the key is on (key is in run position, engine off). Sometimes it is delayed, and sometimes it doesn't light up until the key is in the start position. The van starts and runs well. Sometimes it won't happen for a couple days, and sometimes it will happen every time I go to start it.
The following codes appear after it has happened a handful of times:
P0100-mass air flow circuit
P0102-mass air flow circuit low input
U0155-lost communication with instrument panel cluster control module
P0500-Vehicle speed sensor "A"
U0101-Lost communication with TCM
I did recently replace Fuse box 1 to fix some other weird electrical issues.
Any help on what could be causing this is greatly appreciated.
In the following video it shows the delayed power concern, then I remove the key, reinsert it , turn to the run position and there is operates correctly the seconded time.
https://share.icloud.com/photos/0YEetNL8hibNKjMJXzBGNuoyg
