For simply clearing a check engine light (without actually addressing the problem), the AP200's "Basic" profile (which was in it when you opened the box) should be able to do that.does anyone have a suggestion for how to make this work? My objective is to clear the check engine light briefly for a smog check.
I do not believe this is correct. Mine works with Benz_Sprinter manual vehicle selection and several people have chosen the Dodge and had to get Autel to reset their free option, removing it so they can choose Benz_Sprinter.Haha. Figured out my own problem. For sprinters made between 2002 and 2006ish with a dodge logo on them- you need to get the Dodge diagnostic package!! (Obviously )
Awww.... come on .... you've seenKOEO???
Bobnoxious I was wrong when I claimed that the Dodge diagnosis package works for 2004 Sprinters. So I deleted the post that your reply relates to. you might want to delete your reply.Excellent!
Successfully diagnosing a problem is certainly a pleasurable dopamine moment.
Thank you for sharing your experience with AP 200 and encourage you to share more?
Come on Dick, at least get it right....Awww.... come on .... you've seen "Key Out, Engine Off" before, haven't you?
Thus demonstrating the problem with using acronyms instead of spelling it out.Come on Dick, at least get it right....
It should be Key ON, Engine OFF.
Just ordered but am unclear how to find out if mine is a '903' or something else as mine is also a dodge and the vin may also not be recognised. 2006.Re: Autel AP200 screen shots
Let's put them in-line for the folks: (if you refer to his PDF file, you can blow them up larger)
--dick (whose AP200 is on the way (in theory))View attachment 114151View attachment 114152View attachment 114153View attachment 114154View attachment 114155
If it is a 2006, choose Benz_Sprinter from their "store" as your free vehicle. Then choose manual selection and then Sprinter, and then either the lines starting with 901 or YD and then your country. Both work, with different modules working on both. Then try the different modules. If they don't talk, try the other vehicle selection. You might have to use both to get all of them as Autel did not record which modules were in which vehicle.Just ordered but am unclear how to find out if mine is a '903' or something else as mine is also a dodge and the vin may also not be recognised. 2006.
