LITHIUM BATTERY UPGRADE
I recently replaced my four AGM house batteries with lithium. I had the opportunity to test the new batteries over the last few weeks on two camping trips to the local mountains.
My original AGM batteries are three years old but still have 95%+ of their original capacity. They are Fullriver 224 amp 6 volt batteries which are used by a number of the larger van conversion shops. They are a high quality but expensive battery. I went with the original AGM batteries at the time primary due to the cost of lithium and the cold weather limitations.
The biggest advantage of the lithium batteries over the AGMs in my opinion is usable capacity. I rarely could get more than 30% capacity from my AGMs before the reduced voltage caused larger devices to complain. This included the microwave, coffee maker, and water heater.
In the last few years lithium battery costs have dropped. I purchased four Lion 105 amp/12 Volt batteries from Costco during a limited sale. Each battery was $700 delivered. I had the option of installing these new batteries in my rear cargo compartments which I sized specifically to hold up to 8 GC2 sized batteries. However, I did not want to sacrifice all that valuable cargo storage for the four batteries. Instead I elected to replace my existing under mount AGMs with the lithium.
My four AGMs were mounted in a pair of steel cages that attach just forward of the rear wheels. I use a motorcycle lift to position the batteries heavy batteries before bolting the cage in place. Because the new lithium batteries were smaller dimensionally i was able to wrap the batteries with both a battery heater and a layer of 3/4” minicell foam for insulation. I also added 1” of foam insulation under the batteries and another layer of minicell foam on top. Once installed I added a layer of Refectix around each set of batteries, partly to minimize the heat from both the roadway and the exhaust.
The 120 volt battery heaters are rated for 80 watts but testing showed they put out about 60-65 watts. To control the battery heaters I installed a pair of Inkbird temperature controllers to turn on the battery heaters at a set temperature. The Inkbirds are DC powered. I have the two Inkbirds connected to a dual DC/AC relay to activate the heating pads.
I also installed two Victron Battery Sense bluetooth temperature monitors. These talk to the Victron MPPT, if temps drop below 41F then MPPT shuts down. I can also monitor the battery temps from my phone.
For most of my camping adventures the battery heaters will not be needed. For those few times the batteries are exposed to sub freezing weather I will energize my freeze protection circuit to use the heating pads.
My initial camping adventures have been successful with the lithium batteries. Under a 1200 watt load the batteries maintain 13+ volts. Under a 2000 watt load the batteries maintain 12.5+ volts. Another bonus is the weight. The new batteries weigh 23 lbs each compared to 68 lbs for one AGM.
I have reprogrammed both my Victron MPPT and Balmar voltage regulator (auxiliary alternator) for the lithium batteries. I changed the default lithium settings on the Balmar to more closely match those on the Victron. I also added the optional Balmar battery temperature probe so the alternator charging can be shut down for high battery temperature.
The new lithium batteries are now taking full advantage of both my 600 watts of solar and my 280 amp Nations alternator. The ability of the lithium batteries to take a large charging current is very apparent. The solar has repeatedly hit almost 500 watts peak. The auxiliary alternator will easily push over 100 amps even when the SOC exceeds 95%.
