Baby Shamu - 170 4x4
gltrimble
Is it safer to secure the brackets through the frame rails? Not sure if it is doable for regular DIYer.
I believe the Mercedes Body Builder document specifically states to not drill or weld on the frame rails. Some installers will “wrap” the seat mounting bracket around the frame rail or the crossmembers for added strength. In my opinion a backing plate of sufficient size and thickness is adequate to secure the seats.
cheapren
Got you, thanks.
kfox
Ken
What an incredible build! Sure wish I found your thread before I started. I have nearly the identical layout and am contemplating using the 31" transit seats, but it looks like I'd only have about 15" between the seat and the kitchen cabinets. Do you happen to know how much room you have there?
gltrimble
16” between my Transit seat and the galley. Post #240 in this thread provides more details and pictures.
sue_ger
After 2+ years of effort on my van conversion I thought it was time to document the work. I have been promising to start this build thread for the past few months. This build thread will hopefully move at a relatively fast pace given that the van is 95% complete. I will start off with an assortment of pictures to provide an idea of what the mostly completed van looks like before I get into additional build details in a mostly chronological order.
This is absolutely amazing!!! Would you, by any chance, have a kind of timetable, showing all the steps to a build, in order??
gltrimble
“This is absolutely amazing!!! Would you, by any chance, have a kind of timetable, showing all the steps to a build, in order??”
I do not have any detailed build schedule. Most of the build was from the bottom up starting with the undercarriage batteries and plumbing followed by interior flooring, seats, electrical, plumbing, and insulation. The build took me about two years and 2500 man hours to complete but the van was usable after the initial six months with plumbing, electrical, solar, cooktop, fridge, and a bed. The shower and much of the cabinetry came later. My build thread is mostly in chronological order so hopefully that will give you some idea.
Dann
PROPANE SYSTEM
My propane system consists of a Manchester 6813 tank which feeds a standard two stage propane regulator. The low pressure propane feeds my Force 10 two burner range and oven as well as my outdoor portable fire pit.
The Manchester 6813 propane tank is perfectly sized to fit under the Sprinter. The tank measures 10”D x 23”L. The space on my drivers side measures approximately 12”W x 13”H. This tank has a volume of almost 7 gallons and can reportedly hold 5.5 gallons of propane. I have managed to get a maximum of 5 gallons into the tank which has lasted me for well over a year before refilling.
Manchester Tank 6813 10 x 23 Horizontal 6.9 Gallon Capacity LP Tank https://www.amazon.com/dp/B005GY9UHY/ref=cm_sw_r_cp_tai_4fGhEbG80Y4FZ
On my 170 van this propane tank fit just behind my Isotemp water heater and forward of my driver’s side batteries. The gauge protection shield hangs down just below the van sheet metal providing just enough room for refilling at my local propane distributor.
I looked at a few 8” diameter propane tanks but most were longer and had a smaller volume. I modified the hanger brackets on each end of the tank to provide an optimum amount of up and down adjustment. The custom made brackets holding the tank are secured to the van crossmembers using 5/16” Rivnuts. The forward mount is shared with the Isotemp water heater.
To monitor the propane level I installed a snap on magnetic dial gauge. The tank comes with a built in level indicator. The magnetic dial has a two wire feed which is connected to my See Level tank monitoring system.
Manchester Tank G12653 LP Gas Tank - Snap-On Dial Gauge https://www.amazon.com/dp/B005GY9UTC/ref=cm_sw_r_cp_tai_O3GhEb1GX6PK7
I used a 10’ long high pressure propane hose to supply my regulator which is mounted to the backside of my slider door step. I wanted both high and low pressure propane available on the passenger side to feed my portable campfire pit. The hose is rated for 350psi.
Bayou Classic 10' Stainless Lpg Hose https://www.amazon.com/dp/B00LXNYN9C/ref=cm_sw_r_cp_tai_xzGhEb14CQ478
The regulator is a standard horizontal two stage propane unit.
Camco 59323 Horizontal Two Stage Propane Regulator https://www.amazon.com/dp/B0024E6TQY/ref=cm_sw_r_cp_tai_tDGhEbW12WBGA
I used an assortment of low pressure hoses to supply my range and a quick release for the campfire pit. I installed a valve just upstream of the quick release just in case it leaks. The low pressure hose supplying my range follows a circuitous route thru the slider step and then up and over my water tank. The propane connection is accessible via the downdraft vent at the rear of the range.
Camco 59913 3' Propane Hose Assembly - 3/8" Female Flare x 3/8" Female Flare https://www.amazon.com/dp/B007HG7Y7M/ref=cm_sw_r_cp_tai_wFGhEbB7D8KPY
GASPRO 3/8 Inch Natural Gas Quick Connect Fittings, LP Gas Propane Hose Quick Disconnect Kit, 100% Solid Brass https://www.amazon.com/dp/B01MV458B1/ref=cm_sw_r_cp_tai_5FGhEb00TG8W9
Homewerks VGV-1LH-T2B Premium Gas Ball Valve, Flare x Flare, Brass, 3/8-Inch https://www.amazon.com/dp/B0046HAANU/ref=cm_sw_r_cp_tai_pHGhEb0DX41QH
I purchased a Camco portable fire pit and a 12’ long low pressure propane hose which allows me to position the fire pit along the passenger side. I have plans for an alternate high pressure propane connection for the fire pit in the future.
Camp Chef Gas Fire Ring https://www.amazon.com/dp/B000L4HSH8/ref=cm_sw_r_cp_tai_YQGhEbD5MWWZ5
DOZYANT 12 Feet 3/8 inch ID Natural Gas Grill Hose with Quick Connect Propane Gas Hose Assembly for Low Pressure Appliance -3/8 Female Pipe Thread x 3/8 Male Flare Quick Disconnect - CSA Certified https://www.amazon.com/dp/B01CLJFSIG/ref=cm_sw_r_cp_tai_eQGhEb1JQ3HS5
The interior range/oven is a Force 10 two burner. It is very compact measuring 16”D x 19” W. The oven is 0.7 ft3. Made for marine use, the oven door retracts beneath the oven when open. I installed a stainless backsplash and a downdraft fan along the wall.
I keep revisiting your build as I advance in mine
I need to install my regulator under the van similar to yours. How is yours held in place?
gltrimble
I used some small screws thru the slider step well sheet metal. I then covered the sheet metal and screw heads with some thin foam and Loncoin. It has worked well but if I need to service the regulator I would have to peel back the Loncoin to remove the screws. Next time I might consider tack welding the small studs to make for easier removal of the regulator.
