finkadelic
Hi all,
I'm getting these codes on cold start up. They are related to glow plug 1 and the module.
I thought perhaps they were being caused by a chafed wire bundle, and i did see a bit of chafe around the fuel filter (just the outer sheath). I moved them around and covered the bundles with some radiator hose material. However, i'm still getting the codes.
The thing is, if i clear the codes, they don't come back when the engine is hot. Only appear on cold starts. I assume this means i actually have a glow plug issue.? I believe both the plugs and the relay module are original (121k) to the van.
Looking for opinions - should i just go ahead and replace the whole setup with the Euro parts kit? Or is it worth it to trouble shoot each individual plug and using some an inline fuse setup with the module plug to test individual plugs. Presumably, if one has gone south, the others are soon to follow? (Also it may have damaged the module).
