I have learned a lot from so many of build threads on this site, which means it is time to start giving back. If you are expecting another amazing build (or build thread), well this isn’t likely to be it.
Our 2019 RWD 144” HR sprinter arrived in May, and the build has started as it will go on: slowly.
Most things in our dream come in twos: two people, two mountain bikes, two folding kayaks, two burner stove. The most notable exception is that we can’t really do trips with just two pairs of skis.
If our design doesn’t suit your needs, don’t worry, it suits us.
I stole more from traipsingabout.com than anywhere else, but a lot of you on this forum will see your ideas borrowed, re-purposed, twisted, or otherwise used without adequate thanks. I owe you for sharing what went right and, often more usefully, what went wrong.
Our core layout is the now-common garage style with two sliders. Fresh and hot water tanks will be near the centreline in the garage so they don’t freeze in winter mode. The tanks will be framed-in, partly to support the bed, but also to protect bikes from loose payload. The original idea was to have a big open garage, but we slowly realized that dividing the space would let us carry more gear. Imagine traipsing about with tanks under the central storage unit.
A small fridge, storage, and a bench/head will go on the windowless port side, and a storage cabinet/sink/workspace will block the aft half of the door. More port-side storage on the bed platform will make the bed narrower and eliminate the need for upper cabinets.
Because I studied engineering way back when, the build will be complex. After 15 years with a small sailboat, I have experience in cramming life into small spaces and a lot of nautical terminology to add confusion to conversations.
You have been warned.
