EGR VALVE cause low power?
LivLife
Not sure if I may ask this here. Would a dirty EGR valve make my 2005 Sprinter loose power or have less power?
CGKMGK
Re: EGR VALVE
Sure will. But also check for loose intake hoses and tubes feeding the air from the intercooler to the turbo.
An air leak will have the same effect. It will cause the engine to into LM (limp mode) and severely limit the power you will get.
You can DIY the EGR valve R&R for cleaning. Do a search here for the procedure.
Good Luck
