Need an aftermarket tire pressure monitoring system for '08 Sprinter RV.
Any suggestions or advice?
I'm thinking about the units that screw onto the end of the valve stems but have concerns that the added weight on the ends of the long valve stems might cause undue stress at the base of those stems that could result in failure and loss of pressure. I also wonder if that little bit of added weight will affect the balance of the wheel.
