You mentioned some of the downsides including poor implementation, under-sized units or fittings and potential seal issues in very cold climates. Catch cans aren't generally used as OEM equipment because they are not set-and-forget, people barely bother to change their oil. I'm willing to go to a little extra effort now to prevent sludge buildup later.However, if you read through this thread, there's evidence presented by knowledgeable folks that using these devices may actually be detrimental. You had one person post a picture of the inlet of his turbo with a puddle of oil that bummed him out. And you had another member mention that oil introduced into the turbo is beneficial. Who are you going to believe? Personally, I think I'd lean towards the MB engineers who designed the engine.
There's also been evidence introduced that says it's bad to add complexity and backpressure to the crankcase vent system. And if it freezes, your engine is toast. What's this do to your warranty if you end up damaging your engine?
Thanks for the post, I have the same catch can ready to install on my new VS30 4x4 Crew, as soon as it gets here in hopefully several weeks. After looking at many different catch cans this one was my choice, although the Provent (if that’s how it’s spelled) was my next option. I’ve always installed catch cans on any of my forced induction engines, on non forced induction I never worried about using a catch can. Again thanks for the write-upI did a bit of searching for this but there doesn't seem to be a huge number of posts for oil catch cans. Hein, did have three photos posted for this (of course he did) but I figured I would add what I could after doing the install myself.
Ok, so why a catch can?
Well, simple - I didn't want the EGR gasses containing oil to recirculate into the engine intake. If too much oil enters the intake it is known to coat the walls of the engine with oil which allows carbon build up. Having owned a BMW with the N54 engine I know this is a serious issue that should be avoided. However, there doesn't seem to be a dedicated oil catch can system you can buy for the OM642. I was told to buy this catch can which seems to be a top of the line catch can and has hoses that will work with the Sprinter system.
After taking the EGR hose apart and removing the air intake to the turbo, I found oil in the system :-( I was especially bummed to see this given that my van has 4,100 miles on it...
Anyway, here is a link that should show what I did and how I did it.
Photo 1 - Oil in the turbo intake.
Photo 2 - Oil on the sensor that is right before where the EGR hose connects to the air intake.
Photo 3 - Oil on said sensor
Photo 4 - Oil on hose that connected to sensor
Photo 5 - Location of catch can. This is below the air filter on the passenger side of the van. There are a few predrilled holes in the area that I widened to accomidate a 5/16th bolt. I would use something a bit smaller to prevent having to ream the holes to make them fit this bolt size. Use the red oil dipstick to orient the placement of the catch can. I did cut the bottom 1/4 off of the mounting bracket and drilled two holes in it to mount it in this location.
Photo 6 - Hose leading from catch can to air intake.
Photo 7 - Hose leading from EGR to catch can.
Photo 8 - Shows how hose goes from EGR to bottom of catch can then from top of catch can to air intake.
Photo 9 - Hose from catch can to air intake.
Couple of notes -
All hoses are 3/4
I cut into the EGR hose close to the firewall and then discarded the rest of the hose.
A 3/4 - 3/4 hose connector was uses to connect the EGR output to the hose that runs to the bottom of the catch can.
Have you installed the catch can yet? Im thinking of putting one on my 2020 crew I was looking at the terratuff SEPR8R from Australia. Was it a hard install?Thanks for the post, I have the same catch can ready to install on my new VS30 4x4 Crew, as soon as it gets here in hopefully several weeks. After looking at many different catch cans this one was my choice, although the Provent (if that’s how it’s spelled) was my next option. I’ve always installed catch cans on any of my forced induction engines, on non forced induction I never worried about using a catch can. Again thanks for the write-up![]()
Yep here’s my write up on it for you to look overHave you installed the catch can yet? Im thinking of putting one on my 2020 crew I was looking at the terratuff SEPR8R from Australia. Was it a hard install?
