Passenger van rear floor material and plugging holes
jbm-sd
I have a 2016 Passenger van, and it comes with a corrugated plastic floor, rather than the plywood floor of the crew and cargo vans. I plan to remove the rear-most seat brackets, and I want to make plugs for those bracket holes in the floor, and incorporate some kind of recessed cargo anchors or something similar.
I'm wondering if anyone knows what kind of material the OEM floor is, and what I could use as a plug material and how to bond it. I just need the bond to be strong enough to maintain the plug in place, any loads would be transferred through it to the sheet metal floor. I plan to adhere coin flooring over the whole thing, so appearance is not an issue either.
gltrimble
2017 170 4x4
It will be difficult to get a strong bond on the plugs unless you raise the floor and laminate the backside of the plugs. That is what I did. The factory composite floor is only 3/8” thick.
I raised the floor 1/2” and reinforced critical areas with 1/2” Baltic ply. This also allows you to install surface mount L-Track which is 1/2” deep. The remainder of my floor was filled with poly iso insulation.
jbm-sd
My floor material is a bit different, a kind of corrugated polymer. But I agree, I'll probably need to add some height around the openings to provide 3 dimensions of bonding/support.
I'm just trying to figure out what will make a good bond with the floor material.
kcshoots
VanTripping.com
You can fill it with wooden plugs to match the holes and glue those in. You may not even need glue if a tight fit and a solid surface flooring over it will bond all of the plugs to the main floor. I have a set of Hein's wooden floor plugs if you want them, as I couldn't use them as I had originally planned.
gltrimble
2017 170 4x4
This is what the floor in a passenger van looks like. Since I don’t know the material, I’m having trouble selecting an adhesive/filler.
Definitely plastic. First time I have seen a floor like this on a Sprinter. Does it compress easily under weight? Perhaps Mercedes assumes no significant cargo in a passenger van?
wquek
Work in progress
Looks like it is the V39 option.
GSWatson
2013 144
I’d be interested in the plugs; my project has the wood floor and we’re using cork on top.
Greg
kcshoots
VanTripping.com
Greg
I'll PM you so we can coordinate.
KC
mike183
Just found this thread searching for factory floor reuse options. I just bought a 2019 144 crew van and its got the factory plastic/ ply floor composite material. I think I am going to reuse it after I lay down some mini cell foam under and then do a rubber coin floor over it in the garage area. Not sure I want an added layer of ply under the factory floor like you did for height reasons. How has this set up been working for you a year later?
gltrimble
2017 170 4x4
My flooring has worked out great and I would do it again the same way. I had to add the 1/2” ply under the factory floor in order to provide enough depth to install the recessed L-Track. The added 1/2” also allowed me to extend the floor over the slider step for my galley. And it provided for space for some added insulation. More details of my flooring install are on my build thread including installation of my Loncoin vinyl flooring and boat carpeting.
mike183
reading through your build thread now. Not as much detail on the floor build as the other parts. Why did you put the factory floor back on top of the ply wood? Why not just leave it with the ply and then vinyl on top? I am thinking this causes a height issue for some
johnc711
Is there some issue other than filling the seat platform holes for not simply using the factory V39 option above and nothing else? I assume it doesn't need an additional vapor barrier and from my experience driving it's pretty quiet. Could maybe put down some lizard skin or something adhesive based vs spray; and then use the V39 and cover with material of choice?
