Been reading the forum for a while now and finally getting my build going, I picked up a bunch of parts on Black Friday this year and trying to arrange them in a way that works now which is probably not the best way to approach, but hey...
This design borrows liberally from some of the active members here but has a few unique aspects. I have a 2017 144 Crew 4x4 with Aux Battery. We are using this as a weekend camper for a family of 4 and is my daily driver as well.
The diagram is still under construction a bit but thought I would try and get some feedback before finalizing (some missing runs, terminals, wire gauges, etc). Trying to figure out how to make it not look like a mess in omnigraffle still
. The PDF is easier to read the small text in.
The plan is for equipment under the passenger seat to be wired to the Aux battery and everything else to be wired to the house batteries. They will be connected through the Magnum MS2012 via a Blue Sea Rotary Switch for charging while driving.
Aux Battery (Stock):
House Battery ( 2x 170AH Renogy Lithium):
Solar Charging:
Inverter/Charger:
AC Loads:
DC Loads:
The 12V heater and the Air Compressor will be on separate circuits b/c the Paneltronics panels don’t have 35A breaker option and the rocker switches in the panel are only rated to 20A.
After putting this together I have a few questions I was hoping the forum members could help me with:
Anything else I should be concerned about or need to adjust? Thanks!
- Espar D2 under passenger
- Rockford Fosgate PBR300X4 driving front and rear Hertz speakers, connected to stock head unit for now
- Samlex PST-600-12 Inverter
Solar Charging:
- 3x 100W Renogy Eclipse Panels on Roof in Parallel
- Renogy Rover 40A MPPT Charger
Inverter/Charger:
- Magnum MS2012
- Can be connected to shore power or vehicle inverter via BlueSea Rotary Switch
AC Loads:
- True Induction TI-1B Stove w/ dedicated outlet
- 4x Outlets:
- Laptops
- Electric Kettle
- Maybe Microwave or Instant Pot
DC Loads:
- MaxxAir 7500 Fan
- Lighting:
- 2 Pairs of LED Floods on Roof (Left and Right)
- 1 Pair of LED Floods on A Pillars
- Backup Light mounted in Camera Housing
- 8 3w LED pucks in headliner
- 6 3w LED pucks under cabinets
- LED strips in Galleys
- LED Work Lights on Rear Doors
- TruckFridge TF49DR-SS
- 4x 12 Volt Outlet Panels
- VIAIR 20001 Air Compressor Kit
- Shuffle 3 GPM 55 PSI Water Pump
- Whale Pumps 3gallon 12v Water Heater
- Theres a jump from 250A bus bars from Blue Sea all the way to 600A, I am assuming because of the 300A spec’d fuse for the inverter I need to go with the 600A bus bars?
- Is it ok to have 2 terminals on one post of the main bus bars or should I get the 8 post versions?
- Are the 300A shutoffs that I am using for the battery and the inverter sufficient or should I swap them for 350A variation to ensure the fuse fails first?
- Do I need to protect the Blue Sea A/C Switch that I am using to switch between the vehicle inverter, shore power and off? Are 30A breakers ok here if so, or should the be 25A?
- The Renogy batteries have overcurrent protection which can be reset only using their controllers (which I am), do I need additional protection with some sort of low voltage cutoff? Opinions on if the built in overcurrent protection is sufficient?
- How should I size the breaker going to DC distribution panels? Max possible usage vs most likely max scenarios?
- Is connecting the Renogy Battery Monitor to the same shunt that came with the Magnum BMK kit the optimal thing to do?
- Is there a simple way to add monitoring for the aux/starter battery while in camp mode?
