Skip down a bit in this post for T1N parts info. Near the end is a plug and play NCV3 option. That NCV3 option does not allow TSP safety system activation.
OK people it's time for me to confess that I (yet again?) put out some misinformation on a forum. I have admitted to being a parrot other times. This time I added to the info to the point of being way wrong.
One of the posts is here:
https://sprinter-source.com/forums/showpost.php?p=53264&postcount=4
The bold text above sounds pretty good doesn't it? Except that it's completely wrong [For NAS aka NAFTA Sprinters prior to 2010 MY], it would be great.
After posting my "ESP, ASR OEM Trailer Harness Wiring" question and not getting any definitive answers
That post is here:
https://sprinter-source.com/forums/showthread.php?t=6918
I decided to stop being so lazy and follow up with Dodge. I sent an e-mail to them 7/12/09 basically asking whether the Sprinters with OEM trailer harness interfaced with the ESP®/ASR or had TSA trailer stability assist. If they did, what years were included.
After a few e-mails and phone conversations I finally got my answer from Dodge today in a voice message. TSA has not been available for NAFTA Sprinters to date. It is expected in model year 2010. There is no interface with the ESP®/ASR by using the OEM harness.
Given the fact that there is no interface with the computer controls I personally find it difficult to justify the expense, installation effort, and complexity of the OEM trailer light harness over a properly selected aftermarket trailer light module which uses low current trigger signals and a dedicated 12 volt source. All the OEM harness does is make the trailer lights work, as does a light module.
My sincere apologies for helping to lead anyone down the wrong path. Hope this does some good. vic
2011/08/18 edit: Wire colors from my 2004 which should be standard for all NAFTA T1N's can be found here. Go to post #4.
https://sprinter-source.com/forums/showthread.php?t=3301
TSP and 2010 MY
As of NAFTA model year 2010 the TSP feature is available on our Sprinters. That is an excellent reason to use the OEM harness. An aftermarket trailer light module and brake controller will not allow activation of the TSP feature. That said, the TSP is not available in earlier models so I feel a powered aftermarket module may be a good choice for some people. Altered Sprinter provides good information about TSP in post #20.
Any Euro model Sprinter owners reading this thread can ignore the electric brake information as I'm told they are not applicable.
20170809 Edit: Members often ask what parts to buy.
T1N or NCV3 (Traditional wire tap module.)
I mounted this to the under panel just aft of the T1N spare tire.
Tekonsha 119147 ModuLite HD Protector Trailer Light Power Module
https://www.amazon.com/gp/product/B00ASY29C0/ref=oh_aui_detailpage_o05_s01?ie=UTF8&psc=1
T1N or NCV3
I used ss hose clamps to strap this to the hitch structure.
Hopkins 47185 Multi-Tow Adapter
https://www.amazon.com/gp/product/B0002Q80GS/ref=oh_aui_detailpage_o05_s01?ie=UTF8&psc=1
T1N or NCV3 (Basic brake controller.)
Older model timed brake module. (Fine for small(er) trailers. Ignore "Does not fit".)
Reese Towpower (74642) Brakeman Timed Compact Brake Control
https://www.amazon.com/gp/product/B0016KA9PY/ref=oh_aui_detailpage_o05_s01?ie=UTF8&psc=1
T1N or NCV3 (Proportional brake controller.)
Some (eg. - Sailquik Roger) prefers and recommends a more modern proportional brake controller. It is the better choice overall if cost is not an issue.
https://www.amazon.com/s/ref=nb_sb_...rh=n:15684181,k:proportional+brake+controller
T1N Trailer Hitch
Fits a 2500 140 WB T1N with either the step bumper or standard bumper.
Reese 33089 Class III Custom-Fit Hitch with 2" Square Receiver opening, includes Hitch Plug Cover
https://www.amazon.com/gp/product/B000RNW5PI/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Added:
Some comments OEM Added Harness vs Aftermarket Module
(Admittedly somewhat biased.)
Aftermarket Powered Module
Pros:
Readily available.
Less expensive.
Easier installation.
No relays in body panels to get wet and fail.
Cons:
It's not OEM.
Won't enable TSP trailer safety.
Added OEM Trailer Light Harness/package
Pros:
It's OEM
It *may* play better with parktronic, etc.
Cons:
Can be difficult to source.
More expensive.
Needs to be dealership programmed.
More difficult installation.
Doesn't play well with LED trailer lights.
Won't enable NCV3 - 906 TSP trailer safety (unless exclusively installed at the factory. 2016?+ can now have TSP added by a dealership).
Has relays and wiring in body cavity that get wet and fail.
My recollection is that the T1N OEM suffers the wet relay problem. I didn't dig up any posts. Here's some NCV3 comments related to wet relays and failure.
ADDED.
In newer NCV3's apparently Mercedes saw the light and moved the relays to under the seat. Roger revealed the change.
Added:
FOR NCV3 Sprinters.
Apparently eTrailer now offers a plug and play trailer light powered module which connects into the tail lamp assemblies.
Thanks goes to Kevsuda.
2017 NCV3 is apparently available too.
*******Mike,
Glad I could help. Not that you asked, but to expand a bit. The OEM harness doesn't just take care of the lights, it also lets the computer know that there is a trailer being towed. That affects the way the computer reacts to a skid situation. Because I tow only about 3000# and towing is relatively infrequent I decided that the installation time and cost was not worth the OEM for my situation. By using a trailer light module as I have one ends up towing without the computer control ESP and ASR aware of the trailer being there. If you plan to tow more weight than I do, or plan to tow a majority of the time I think the OEM harness and included computer control is worth considering. It is a bit pricey and much more involved to install.
If you do go with the aftermarket module you may want to consider what I installed. When I ran the dedicated 12 volt power back to the left rear of my van I used a larger feed wire. I fused it at 30 amps at the battery (I think...maybe 40. It's a big cable that was already there for a handicap lift) and then split it off to 2ea. fused 20 amp circuits in the area above the rear light pod. One 20 amp went to the trailer module. The other 20 amp went to an accessory (cigar lighter) receptacle for camping use. It has often been convenient to have that 12 power available in the back of the van.
Hope this does some good. AP
That post is here:
TSP and 2010 MY
T1N or NCV3
T1N Trailer Hitch
Added:
Pros:
Readily available.
Less expensive.
Cons:
It's not OEM.
Pros:
It's OEM
Cons:
More expensive.
Brian, we were informed by our neighbor last night that one of our tail lights was on. I went to check it out and sure enough the left light was on, so I disconnected the batter, TA DAAA the light and everything else went dark. Connected the battery again and the light came back on, disconnected the battery again and went inside. Today I checked this great site and found your message. Went to our 2007 NCV3, found the 3" plug and pulled the DRIPPING wire harness out. I then found the drain hole and got out of the way of the steady stream of water. I connected the battery again and found one of the relays was warm, not hot AND the light did not come on unless directed by the light switch. Thank you so much for your message!
****************************Funny thing is, same thing happened to me. First, I noticed that you have an aftermarket towing hitch and harness. Is that correct? If so, try to disconnect your towing wiring harness from your main battery.
Dodge towing wiring harnesses consist of six relays. They are located below the tail light on the driver's side. When I opened mine, three of the relays were corroded and wet, but I only had to replace one. Check yours for any corrosion and if neccessary, change the relay. I got mine from the Dodge parts department at the dealership. To prevent it from happening again, make sure you move the relays up and isolate them so they don't get wet.
Hope this helped!
ADDED.
*******************Guys,
I think you are mixing T1N (Dodge or Freightliner) 2002-2006 and early NCV3 (Dodge/Freightliner 2007-2009) with >2010 Mercedes Benz/Freightliner NCV3 trailer tow harness's.
There are no relays anywhere near the back of a 2012 NCV3.
All the relays and towing modules (TSA/Trailer Brake Controller) are under the driver's seat.
They are most often located on an upper module mounting bar above the normal electronics
found in Sprinters without the towing harness.
Roger
Added:
FOR NCV3 Sprinters.
Your model year (2007 - 2013) can be entered. (As of Dec. 2017 a plug and play kit is not available for T1N's.)I ordered this one last week. https://www.etrailer.com/Custom-Fit...Sprinter/2011/118650.html?vehicleid=201151735
https://www.etrailer.com/Custom-Fit...ter+2500/2017/118649.html?vehicleID=201751730
I’ve two buddies that use this system. It’s plug and play. Installs in a couple hours.
eTrailer shows how to use a simple lever and bathroom scale to measure tongue weight.
And other options. https://www.etrailer.com/faq-how-to-determine-trailer-tongue-weight.aspx
