I used the generally accepted method of wiring my MPPT on my last build (a T1N), connecting a wire from the Bat+ on the MPPT to the physical battery +, and the Bat- wire to the physical battery -.
Now I'm installing an MPPT in an NCV3 that came with a stock aux battery in the engine compartment, and I'm curious if there's any reason not to wire the Bat+ wire from the MPPT to what they call the "Electrical Connector Aux Battery" on p8 of this document: https://sprintervanusa.com/files/2016/07/AuxBattery-Mercedes-retrofit-doc.pdf. This is essentially a positive terminal under the driver's seat, which connects to the battery isolator and then onto the physical battery + on the house battery in the engine compartment.
My concern is that electricity generated by the solar panel could then feed directly into the loads, bypassing the battery altogether. I'm not sure if there's anything necessarily wrong with this, but wanted to check the wisdom of the crowd.
Pushing the unorthodoxy further, I assume it would be a very bad idea to connect the Bat- outlet from the MPPT to a simple ground, and instead should run it all the way to the Bat- terminal on the physical battery.
Thanks as always for your help!
Dave
Dave
