maxextz
Rollin Rollin Rollin.....
Gear box oil change in pictures
To change the gearbox oil "manual transmission" first locate the filler bolt 1st pic "top left side" then the drain bolt 2nd pic"bottom beside cross member" remember to clean around the filler bolt so as not to get any dirt "crap" in there.
drive around the block "you now have an excuse to pass the hot new chick down the road"
drain out the old oil now that its warm and lose "great in the cold weather" leave it to drain and when your finished your pintcoffee put the bolt plug back in and fill the box with your new oil to just bottom of the filler hole put the filler bolt on and thats it.
the drain bolt had some shavings on see pic
grind em till you find em has consequences
max..........
max..........
