What is this connector?
outbound
06/2500/140
ambient air temp sensor.
it 'plugs into' a hole somewhere behind the bumper cover, immed aft of the lic plate holder
Engineer In Residence
That sensor is important, and can cause LHM if damaged, so make sure it secured against damage and the wires protected from fretting.
Nautamaran
2004 140” HRC 2500 (Crewed)
Limp Home Mode.
Faulty ambient air temp readings can confuse the engine control module’s fuel calculation, so it may panic and reduce power.
Leaky boost hoses; bad MAF sensor; stuck EGR valve; bad MAP sensor; bad O2 sensor; ... and may result in loss of boost, imposed rpm limits, or a crank no-start event. Transmission faults like a bad shaft speed sensor reading or wheel speed sensor can lock the transmission down to 2nd/N/R/P The good news is the control modules store DTCs when thes events occur, and will share them if you ask nicely. :cheers:
-dave
