wisdomracer
2003 Cargo Springer.
OK have been dealing with getting this van running again for the past few days. I will try to give the whole story. Well it sat for a few weeks and it did rain a lot. I started it up and drove it about 10 minutes from my house and it went into limp mode. Showed codes P14841, p1482, and P1354 (bad synchronization between crankshaft and camshaft sensor.) I have been having hard starting problems since I bought it and assumed it was fuel line problems letting air in, which I thought I fixed. When code 1354 came up I decided its time to change the crankshaft sensor. I have already replaced the camshaft sensor with a knockoff sensor from autozone a few weeks ago. I changed the crankshaft sensor with an OEM one and still no start. I purged the fuel line and have no air bubbles. I know its not the best habit but it does start up real quick with starter fluid. Also probably 70% of the time when I start the van it kicks like it is going to start for a second then just turns over by the starter. When I clear the codes as soon as I start it those codes come back up. Any ideas? Sorry for the long message
