Rear end oil fillup hole plug
Ciprian
Spark Plugs not allowed!
The rubber oil fill plug is leaking. Not that much for the oil level to go down, but the differential housing is always wet and dirt accumulates there. Anybody else noticed this? Any fix to it?
Thanks.
sikwan
06 T1N Can
Mine is fine.
Remove the rubber plug, dab your favorite gasket sealant on the plug mating surface, and do not install until it has cured overnight or enough to install dry.
Ciprian
Mine is fine.
Will give that a try. Thanks
