OrioN
2008 2500 170" EXT
Thermostats with degree setting are OPTIONAL. There is a CONTROL in the kits and is precise. It works the same if you know which 'bar' to set it at.Do you have thermostats for these things? IN other words, can you set it to be 70 degrees in the "cabin"?
Also, have any of you used remote starters or timer set-ups? How did they works?
The Airtronic is in competition with upgrading my OEM D5 Hydronic to modify it to preheat the cabin.
I keep getting the "cold shoulder" from my wife about the heat in this thing!![]()
One major advantage of the Airtronic is that it give instant and responsive heat. A hydronic can't. So quick warmups and rewarming after the door is opened is not possible.
Hydronic system uses more battery, as there is an addition water recirculator in the mix. Could be 25% more current.
