Diamondsea
As a result of my posting “Cheap Conversion” a day or two ago under “Sprinter Based RVs and Conversions” there seems to be some interest in the Espar installation. I ordered part number 20-2820-69-02-95 Truck Kit, 12 volt, with thermostat, without fuel pick up. This is an Airtronic D2 with all the parts and little pieces designed for the sleeper cab of a big rig. This version without the fuel tube is a tad cheaper as the Sprinter already has the fuel pickup. This kit assumes mounting on a flat floor with burner connections under the floor. As the floor is not flat under the passenger seat and as the seat has a bigger dimension several inches above the floor I also ordered Angle Mounting Bracket 20-2900-40-00-23.
The first photo looking from the center towards the passenger door tells most of the story. Only about 4 inches of duct was used to shoot the heat towards the back of the van. As I left the foam cover off of the seat base no duct was needed on the cold air return, just the supplied safety screen. The black combustion air inlet goes only about 4 inches below the floor where its end is protected from road dirt by the plastic underfloor storage bin to which the hose is secured by a clamp. The silver colored exhaust hose runs towards the rear of the vehicle about 2 or 3 feet continually downhill (for condensation to drain) secured by a clamp or two and ends secured to the low outside body sheet metal flange with the end pointing down and out to the side. Only about 3 inches is visible from the street. The multi-colored wire bundle has nothing to do with the heater. The heater’s connectors and wire harness are out of view towards the camera. The white fuel capillary tube and fuel pump wire go through the floor. The red stuff is high temp Permatex sealer.
The second photo shows that I used the supplied straight-out outlet fitting in lieu of the rotatable angled one to shoot the heat back along the (cold) floor. The two wires are the power leads to my house electrical system and the thermostat cable. I mounted the thermostat on the van side wall near the ceiling several inches back of the sliding door. As heat shooting out under it and rising might give it false sensing I selected the option to not connect the gray wire which defaults the thermostat to a rheostat controlling the heater’s built-in thermostat in its cold air return.
Sorry, the last photo is out of focus. The hard work was underneath. Note the fat fuel fill enters the tank neat the bottom! As the tank top is up against the floor of the van and as the supplied capillary fuel tube and fuel pump power wire were a tad shorter than I would have liked routing was difficult. The left side of the photo is towards the front of the van. I was able to avoid hot exhaust components by going above their heat shields. I mounted the fuel metering pulse pump on the back side of the cross member to have it shielded from most road dirt. The supplied rubber hose to fit the fuel pump did not fit the MB tube from the fuel tank. I had to buy a few inches of another size hose and have a machine shop make a brass adapter to mate the two rubber hoses as I did not trust the off the shelf plastic one I found.
I used a turkey baster to suck fuel to the fuel pump. At turn-on the heater mostly filled the capillary on its first attempt to start and timed out. I waited and after its built in delay it automatically tried to start again with complete success. Its built in computer does wonders! Sorry, Photos 2 and 3 got reversed.
